Vladi Posted July 31, 2008 Share Posted July 31, 2008 Hi to everyone. As a (brand) new IS250 driver, I have many questions and luckily I found some answers already in this forum. Thanks to all the "senior" members who contribute so much knowledge to the site. I spent some quality time with the search function but could not find a good answer to my question - how long should my stock (I got the upgrade to 18") tires last? I understand that the answer is personal driving habits dependant but for a not very spirited driving pattern back and forth to work in sunny FL (I don't expect more then 10K miles/year) will I be able to get through the 36 month lease without changing the tires? This sticker attached to the back side window that says I can get less then 15k miles out of a set of tires bothers me a bit :-) Quote Link to comment Share on other sites More sharing options...
ajis250 Posted August 1, 2008 Share Posted August 1, 2008 Hi to everyone. As a (brand) new IS250 driver, I have many questions and luckily I found some answers already in this forum. Thanks to all the "senior" members who contribute so much knowledge to the site.I spent some quality time with the search function but could not find a good answer to my question - how long should my stock (I got the upgrade to 18") tires last? I understand that the answer is personal driving habits dependant but for a not very spirited driving pattern back and forth to work in sunny FL (I don't expect more then 10K miles/year) will I be able to get through the 36 month lease without changing the tires? This sticker attached to the back side window that says I can get less then 15k miles out of a set of tires bothers me a bit :-) Welcome, I am not quite a senior member but I think you will be cutting it close. The Bridg Turanza is rated at 140 thred wear and that is rather low but that is way they are sticky, the heat from here won't help so remember enter wide, choose your apex and exit turns wide increasing the turns radius us the technique, don't brake unless necessary and easy on the throttle, also great for your mpg. Ah I almost forgot, check you lease, some will prorate the wear and charge for the rubber left behind or require you bring in your baby with new shoes. Also, celebration donuts are not recommended. :) Quote Link to comment Share on other sites More sharing options...
350lexus350 Posted August 15, 2008 Share Posted August 15, 2008 I've have a 06 IS 350, had to replace front dunlops at 30k miles, still have the oem rear dunlops with 41k on the car, I'd say I will have to replace them at about 45k Quote Link to comment Share on other sites More sharing options...
