045spdIS300 Posted July 27, 2008 Share Posted July 27, 2008 Hi all, When I push on the clutch I get a sqeaking sound. It looks like the cable is covered by rubber boots. IAre there any instruction manuals or easy ways to get some lubrication on that cable. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted July 27, 2008 Share Posted July 27, 2008 You might just need to lube the clutch lever itself. Get some lithium grease, (Don't use WD40 for this, it won't last long enouph, and will drip down the lever to the foot plate.) or some bearing packing grease, and look under the dash on the floor board, you'll see the pivot assembly for the clutch lever. (The pedal you push down with you foot.) Grease that junction up and work the pedal back and fourth to get good coverage and saturation. You should be good to go. Make sure you wipe away any excess grease so as not to get it on the foot plate. That could be dangerous if your foot slips off the clutch. Quote Link to comment Share on other sites More sharing options...
045spdIS300 Posted July 27, 2008 Author Share Posted July 27, 2008 I put litium grease on the plunger rod going through the fire wall. no help. the sqeak is coming from under the car. hosed under the car with it with silicone, still squeaks. if i get ambituous i will jack it and see if i can get to that cable any where. thanks Quote Link to comment Share on other sites More sharing options...
