lexushunk Posted July 26, 2008 Share Posted July 26, 2008 hi just purchased a 2005 rx330 and trying to program the homelink so i can open my garage door but doesnt seem to work i follow the manual with no luck anyone have any idea thanks Quote Link to comment Share on other sites More sharing options...
raymsixsix Posted July 26, 2008 Share Posted July 26, 2008 Welcome to the LOC! Make sure that you've cleared out the old codes in the Homelink, and that you're putting your garage door opener in "training mode." To clear out the old codes I believe you have to hold down button 1 and 3 until the led flashing sequence changes. To put your garage door opener in "training mode," there is usually a button on the back of the garage door opener, that you have to press and complete the programming sequence in about a minute. It helps if you have someone to assist you. Good luck! Quote Link to comment Share on other sites More sharing options...
lexushunk Posted July 27, 2008 Author Share Posted July 27, 2008 Welcome to the LOC! Make sure that you've cleared out the old codes in the Homelink, and that you're putting your garage door opener in "training mode." To clear out the old codes I believe you have to hold down button 1 and 3 until the led flashing sequence changes. To put your garage door opener in "training mode," there is usually a button on the back of the garage door opener, that you have to press and complete the programming sequence in about a minute. It helps if you have someone to assist you. Good luck! thanks. i will try this and report back. Quote Link to comment Share on other sites More sharing options...
lexushunk Posted July 28, 2008 Author Share Posted July 28, 2008 Welcome to the LOC! Make sure that you've cleared out the old codes in the Homelink, and that you're putting your garage door opener in "training mode." To clear out the old codes I believe you have to hold down button 1 and 3 until the led flashing sequence changes. To put your garage door opener in "training mode," there is usually a button on the back of the garage door opener, that you have to press and complete the programming sequence in about a minute. It helps if you have someone to assist you. Good luck! thanks. i will try this and report back. k got it to work thanks ray Quote Link to comment Share on other sites More sharing options...
raymsixsix Posted July 28, 2008 Share Posted July 28, 2008 Welcome to the LOC! Make sure that you've cleared out the old codes in the Homelink, and that you're putting your garage door opener in "training mode." To clear out the old codes I believe you have to hold down button 1 and 3 until the led flashing sequence changes. To put your garage door opener in "training mode," there is usually a button on the back of the garage door opener, that you have to press and complete the programming sequence in about a minute. It helps if you have someone to assist you. Good luck! thanks. i will try this and report back. k got it to work thanks ray You're welcome bud, anytime! :) Quote Link to comment Share on other sites More sharing options...
Galvin Posted July 30, 2008 Share Posted July 30, 2008 Mine is Broken on my 01 RX300 anyone know how to fix them? Quote Link to comment Share on other sites More sharing options...
