Sc300 Build For $20k Max Sound Reasonable?
Can it be done under $20k?
3 members have voted
  1. 1. Can it be done under $20k?
    • Yep - I think it's within reach.
      2
    • No - You're being too optimistic.
Intro:
I love my ES300, don't get me wrong ... but I keep catching myself dreaming for something manual-transmission and rear-wheel-drive. My first thought is: SC300.
Kelly Blue Book lists the value of my ES300 at $11k, let's be reasonable and say I get $10k for it.
Thanks to a recent promotion, I could stand to throw in some cash for a project car - $5k wouldn't hurt too bad, and $10k would be the max I could foresee dumping into the project in the near future, giving me a hopeful budget of $15k and a max budget of $20k.
My question is this: Do you think I could reasonably find a 97+ SC300 frame/body/shell/interior, with enough left over to overhaul and build a 2JZ-GTE, within this budget?
My objectives are:
1) Obviously, manual transmission, RWD, and 2JZ-GTE block.
I'm not looking to build a 1,000-HP beast here, but putting 400 down to the back wheels sounds delightful.
More would be nice if it's within budget. However, I want to run on premium pump gas.
2)
Daily-driver reliability.
I don't want to push the hardware harder than it's "comfortable" with. If I do this build, I'll be intending to keep it for a long time, so I want it to last. This may mean having to "over-build" some aspects of the drivetrain...?
3) Super "clean" look (almost "sleeper" clean) - this means I either need to find an SC300 in good aesthetic shape, or budget in some money for body work and paint. I'd much prefer black. I already have rims & rubber, which will save a few bucks.
4) A nice, but not competition-level sound system. I'm a bit of a music snob, not looking to set of car alarms - I figure $1500 for a stereo system would probably fill the need.
Am I being too optimistic to think a car like this is within a $20k max budget, or do you think it can be done? Thanks for any opinions. It will be a few months before I could start this project, I'm just doing the preliminary research. Thanks again.
Peace,
Pete Zaria.
OK, since I didn't get any replies I went and did some research... Here's my "quick and dirty" SC300 2JZ-GTE shopping list.
Base Car:
Mid-to-late 1990s Lexus SC300. With approx. 120k miles, these seem to go for around $5,000 on eBay in decent shape.
Engine:
2JZ-GTE, less than 40k miles, rebuilt - $2,245 - SupraStore.com
Turbo kit: - $1,700, SupraStore.com
Greddy T61 single-turbo setup w/ manifold and headers
12"x24"x3" aluminum intercooler
64mm Ti-Al wastegate
Stainless steel downpipe & dump tube
Ti-Al 50mm blow-off valve
4" stainless intake
Turbo oil return system
Boost controller
Underdrive pulleys: $370
This kit is rated for 460 rear wheel horsepower on premium pump gas at 17 psi of boost.
Performance ECU & wiring harness: HKS Performance, $1,039
Transmission:
6-speed '98 Supra tranny, rebuilt - $1500 - Everdrive
Performance clutch, flywheel, throw out bearings, pressure plates, slave cylinder & shifter: $2200 from Exedy Racing
Limited Slip Diff: $919, SupraStore.com
Rear Axle, CV joints: $190
Suspension:
HKS HiperMax Coilover kit - $1,997
Brakes:
Brembo Gran Turismo 4-piston, cross-drilled Big Brake kit: $2,781
Seats & Harnesses:
Sparco adjustable buckets & harnesses - $1,200
QTP 3" Electric Exhaust Cutout Kit: $314
O2 sensor simulators: $80
Total: $19,835
I'm sure something will go wrong at some point and I'll end up going over budget... but I think it's possible. I hope to start on this project early next year, or sooner if budget allows.
Any input, anyone?
Peace,
Pete Zaria.
Base Car:
Engine:
4" stainless intake
Boost controller
Transmission:
Suspension:
Brakes:
Seats & Harnesses:
Total: $19,835
Any input, anyone?
Peace,
Pete Zaria.
or what you could do is go for an sc400 an supercharge for probably 6 of 7k w/ installation check this link
http://www.bulletcars.com/superchargers/to...ger-system.html
I'm opposed to a V8 for gas mileage reasons. At low boost, a 2JZ-GTE should still manage 20+ mpg on the highway. I can handle that. Thanks for the suggestion though.
By the way, I realized that the Turbo Package I mentioned from Supra Store is a turbo UPGRADE package for an engine already with turbos, and the 2JZ-GTE I listed is the engine only, no turbos included. So I'd need to fork over some more cash on that. I still think it's doable within a roughly 20k budget, and I hope to start on this project as soon as funding allows.
Any other input, anyone?
Peace,
Pete Zaria.
Loading...
 Share
