doc.okf Posted July 3, 2008 Share Posted July 3, 2008 hey, i just got my lexus is 250, which was being worked on, the problem is that when the car is turned on the engine idles, throttles up and down,( the RPM goes up and down), the power steering dosent seem to work, its verry stiff, and the dash says to check VSC....help please! any suggestions?? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted July 4, 2008 Share Posted July 4, 2008 The idle is controlled by the ECU, so it may just have a programming issue, or somthing in the fuel delivery system is off. Which is probobly why the cel is on (Check VSC). And the 2008 IS model does have stiffer steering than before. I have jumped from driving a Camery to my IS and the steering is night and day in comparison. Quote Link to comment Share on other sites More sharing options...
doc.okf Posted July 4, 2008 Author Share Posted July 4, 2008 The idle is controlled by the ECU, so it may just have a programming issue, or somthing in the fuel delivery system is off. Which is probobly why the cel is on (Check VSC). And the 2008 IS model does have stiffer steering than before. I have jumped from driving a Camery to my IS and the steering is night and day in comparison. hey thanks for your responce. i trying to get somebody to run a diagnostic on the car, but no luck yet..i am all the way in jamaica, so they have little experience ith this model. about the steering, its so stiff that u have to use two hands, and its an 06 model. owh i think i forgot to tell u that it was kinda in a little accident...but not too too bad. Quote Link to comment Share on other sites More sharing options...
