joedoc Posted December 13, 2003 Posted December 13, 2003 I have a nagging leak where the coolant sensor plugs into the plastic reservoir. I have tried tightening the plastic screw and also tried silicone sealant without improvement. Does anyone have experience with this or ideas for a fix? Thanks :(
Lextech2k3 Posted December 13, 2003 Posted December 13, 2003 as a lexus techinician i can honestly tell you that the only thing you can do to fix your problem is to replace that tank...both the sc's and the ls's have this problem...they have since done away with that sensor. sorry to give you bad news...
joedoc Posted December 14, 2003 Author Posted December 14, 2003 Ouch---the lexus dealer here in Cincinnati wants $350 for a new reservoir. Is there a Toyota Supra part that might fit?
AWJ Posted December 15, 2003 Posted December 15, 2003 You're in Cincy eh? Small world. Drop a dime some time. If you want to try to keep the old rez - you will have to try some rigging. I'm thinking if you can find an internally/externally threaded nipple that matches the threads of the sensor, then you could drill out the hole to just under the external thread diameter of the nipple. Then either tap the new hole or heat the insert and the plastic rez will mold into the external threads to hopefully form a nice seal. Or you could make your own out of a plastic bottle of some sort. Get creative. I'm really buisy for the next few months - but if you want, we might be able to meet up and see what we can rig. It might even look good. Don't hold me to it though for now. I will have time come March.
joedoc Posted December 15, 2003 Author Posted December 15, 2003 thanks for the offer. i will try your advice. i also hope to be busy through super bowl week watching the bengals
joedoc Posted December 21, 2003 Author Posted December 21, 2003 I think I may have found a cheap fix. I bought an expansion plug ( 1--1 1/8 in) for 3 bucks that seems to seal the opening well. These plugs are hard rubber with metal washers on each end and a bolt through the center. When you tighten the bolt the rubber is squeezed and it expands out to seal up the opening. I put it through the opening for the coolant sensor, and so far no leaks. Of course the coolant sensor no longer works so need to keep an eye on the coolant level. Hope someone else may find this helpful.
MoneymanMike Posted April 8, 2005 Posted April 8, 2005 I think I may have found a cheap fix. I bought an expansion plug ( 1--1 1/8 in) for 3 bucks that seems to seal the opening well. These plugs are hard rubber with metal washers on each end and a bolt through the center. When you tighten the bolt the rubber is squeezed and it expands out to seal up the opening. I put it through the opening for the coolant sensor, and so far no leaks. Of course the coolant sensor no longer works so need to keep an eye on the coolant level. Hope someone else may find this helpful. ← JoeDoc, Thanks for the tip. I'm having the exact same problem on my 95sc400. I'll try your idea and hopefully it works. See ya, MMM
