Ratatat Posted June 19, 2008 Share Posted June 19, 2008 I have the iridium plugs, but what is the wire set i need for the 95 es300? vehicle has 130,000 miles And does anybody have an EGR delete diagram for this engine? Quote Link to comment Share on other sites More sharing options...
spalkin Posted June 20, 2008 Share Posted June 20, 2008 There are no plug wires. There is an individual ignition coil for each plug. Getting to the back ones is a whole production. Pick up a plenum gasket before you start. Good Luck! :D Quote Link to comment Share on other sites More sharing options...
Ratatat Posted June 21, 2008 Author Share Posted June 21, 2008 ok thats what is was starting to look like, thanks for the tip on the plenum gasket. Quote Link to comment Share on other sites More sharing options...
quick6 Posted June 21, 2008 Share Posted June 21, 2008 Make sure to only use Denso or NGK plugs or you WILL be doing it twice. Quote Link to comment Share on other sites More sharing options...
Ratatat Posted June 24, 2008 Author Share Posted June 24, 2008 found 14 NGK Iridium IX plugs for $6 apiece on Ebay. Which is a perfect number to find. Quote Link to comment Share on other sites More sharing options...
