Dgoude Posted June 17, 2008 Share Posted June 17, 2008 I have a '99 ES 300 with 135K miles on it. I had problems when I bought the car in '02 with 23k miles on it with the VSC and VSC Off lights coming on spontaneously. I took it to the dealership 5 times and they finally decided to replace the on board computer. This solved the problem until recently. The last few months the problem has returned but this time with other symptoms. Sometimes if I punch the gas, whether just starting off or hitting it hard to accelerate, the engine bogs down for a few seconds and then catches. But recently when I've been getting onto the interstate and have had to accel quickly the VSC and VSC Off lights have come on (sometimes with the Check Engine Light and sometimes not) and the car is very sluggish. It was sporadic at first and now it is every time I have to really hit the gas. If the Check Engine light comes on with the VSC and VSC Off lights I have to disconnect the battery and it all resets and goes back to normal until the next time. If the Check Engine light doesn't come on along with the others, all I have to do is shut off the engine and it doesn't come back on again until I have to accel quickly again. I am not a mechanic by any means but do like to DIY and have the Haynes manual. I've changed my rotors before and spark plugs (in a previous car) so I'm not afraid to get my hands dirty if it's something I can do myself. Can anyone help here? Thanks, Dgoude Dgoude@gmail.com Quote Link to comment Share on other sites More sharing options...
smooth1 Posted June 17, 2008 Share Posted June 17, 2008 It sounds to me like the car is going in and out of safe mode as the cel is coming up. It's not a problem, it's the car reacting and protecting itself. Keep in mind, the ECU is not a warning center, it's a logging computer. It logs what is going on in the motor. If a certian issue, say a knock occurs, it simplyy logs the event. If it happens XX times in a short amount of time, then it sends up the cel to say there is a problem that keeps occuring here. If the knock exceeds some preprogrammed peramters, then it can send the car into what is called the safe mode, or limp mode. This mode drastically reduces output and limits RPM's to try and protect the motor from further damage. You may have another bad ECU. Quote Link to comment Share on other sites More sharing options...
quick6 Posted June 21, 2008 Share Posted June 21, 2008 You Should really check the code/codes when the CEL comes on next time as it will give you a place to start your diagnosis. Auto zone and some other parts stores will check it for free and give you a generic code. Quote Link to comment Share on other sites More sharing options...
