Paolo9 Posted June 12, 2008 Share Posted June 12, 2008 Hey all, I have an 02 with the two coin holders and blank switch cover to the left of the steering wheel. Behind the blank switch cover is a 6-wire harness just sitting there. The 04 has a memory seat switch in that space... So... I'm thinking the wiring might already be there? Might just have to add an ECU? Maybe? Bueller? Bueller? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted June 13, 2008 Share Posted June 13, 2008 The ECU is part of the seat, and if I rememebr right, it's a different plug also. But if you were to change the seats to ones that had the ecu, and change the plug, then put the switch in, it might or atleast should work. Quote Link to comment Share on other sites More sharing options...
IS3_FTW Posted June 14, 2008 Share Posted June 14, 2008 Need more info bump. Not enough info Quote Link to comment Share on other sites More sharing options...
