vyhanh Posted December 11, 2003 Share Posted December 11, 2003 Hi, We have 0 (degree F) windchill here. My son's 91 LS400 has problem closing the trunk at first attempt. With several pulls of the trunk release tab, I eventually close it. Same with door (using the lock/unlock switch). Any similar problem ? Any solution? Thanks VH Quote Link to comment Share on other sites More sharing options...
mejojo Posted December 11, 2003 Share Posted December 11, 2003 Oh, my god......32 degrees below freezing? Is that Siberia, Minnesota? I assume that this problem did not exist before the cold snap? Does a grease exist that won't freeze in that temperature? You need to find one and re-lube the latches, first cleaning off any old grease. What is the actual (non-windchill) temperature? Joe Quote Link to comment Share on other sites More sharing options...
vyhanh Posted December 11, 2003 Author Share Posted December 11, 2003 Yes, it is COLD. Non-windchill 8-10. In January/Feb, the non-windchill can get down to -5 !!! Thanks for the suggestion. I have to look real hard for a 'Siberian' grease. Quote Link to comment Share on other sites More sharing options...
