bjjulian1 Posted June 4, 2008 Share Posted June 4, 2008 1. What value bulbs do I need for the license plate area for a 95 ES300? 2. How are they replaced? Will I need to access the bulbs through the trunk area? Quote Link to comment Share on other sites More sharing options...
Lexus2D Posted June 5, 2008 Share Posted June 5, 2008 Iv done mine on an IS with LED but not sure on a ES Quote Link to comment Share on other sites More sharing options...
Lexucan Posted June 8, 2008 Share Posted June 8, 2008 1. What value bulbs do I need for the license plate area for a 95 ES300? #168 2. How are they replaced? Will I need to access the bulbs through the trunk area? Click HERE As Lexus2D stated, you can replace the licence plate bulbs with LEDs if you wish. They last many times longer than incandescent bulbs, and look cooler too. Check out this site for LED alternatives www.superbrightleds.com I bought "cool white" LEDs from them to replace the burnt out front door courtesy lights, the interior trunk light, the licence plate lights, and the 8 instrument cluster backlighting bulbs. Quote Link to comment Share on other sites More sharing options...
jeharter Posted July 15, 2008 Share Posted July 15, 2008 1. What value bulbs do I need for the license plate area for a 95 ES300? #168 2. How are they replaced? Will I need to access the bulbs through the trunk area? Click HERE As Lexus2D stated, you can replace the licence plate bulbs with LEDs if you wish. They last many times longer than incandescent bulbs, and look cooler too. Check out this site for LED alternatives www.superbrightleds.com I bought "cool white" LEDs from them to replace the burnt out front door courtesy lights, the interior trunk light, the licence plate lights, and the 8 instrument cluster backlighting bulbs. The bulbs are accessed through the underside of the trunk lid. It is a bear to do and took me 1 hour start to finish. Hardest part was pulling the plastic plugs to remove the underside insullation. Good luck Quote Link to comment Share on other sites More sharing options...
Lexucan Posted July 16, 2008 Share Posted July 16, 2008 The bulbs are accessed through the underside of the trunk lid. It is a bear to do and took me 1 hour start to finish. Hardest part was pulling the plastic plugs to remove the underside insullation. Not on the 2nd generation ('92-'96) ES300. The licence plate bulbs are accessed by removing the whole taillight assemblies. Quote Link to comment Share on other sites More sharing options...
