I was going through the MAF cleaning procedure very well documented in the following link.
http://www.lexusownersclub.co.uk/knowledge...id=152&c=11
I would really appreciate comments on the followin (I am going to use CRC MAF cleaner that i bought from Kragen)
- Spraying the wires 2-3 times with the cleaner is good enough or do i need to use a cotton bud to clean the wires as the above link says.
I am really scared to damage the MAF. Won't the cotton/thread get attached to the wire.
- What about the Temperature Sensor. Can i spray it with the same CRC MAF cleaner or i need something else.
- Also should i use a cotton bud for cleaning the temp sensor or spray would be good enough.
Thanks a lot.
only spray... never touch the sensor bud.
Thanks for your reply. What about the temp sensor. Can it be sprayed with the MAF cleaner too??
