Hello,
Does anyone know is it possible to replace default navigation screen to music menu after the engine start. As I saw, RX has default function to show GPS every time after you start the engine (after first Lexus sign, there is instruction for operating GPS, agree-disagree, and searching for your location). I want to set audio or music function as default every time when I'm starting the engine instead of navigation
If someone know, it would be highly appreciated
Thanks
I'm pretty sure it's the same proceedure, hit the Info button, then go to screen setting. The first option is Nav default from audio and ac controls on or off. select off. Then you go bacl out from there and hit audio. The nav screen should stay on what ever screen you leave it on last until you change it.
@smooth1
Thanks for advice, it works. But in some occassions Nav screen appears again, of course, when I''m starting the engine. I don't know why..
