Hello everyone. I'm in need of some information; I'm looking at getting a new set of wheels since apparently 2 of my OEM wheels are "bent," according to the service department (although not so bad that they couldn't be balanced out for now). The Enkei RPM2s look nice, but they come in 2 offsets: 38mm and 45 mm. I've read on here that the OEM offset is either 42mm or 50mm, so I'm guessing the 45mm would be the obvious choice? Also, the bolt pattern is 5x114.3, correct? I just don't want to order a set and get them to find out I messed up with the specs. Thanks for your help.
the bolt pattern is correct. 5x114.3
As for the offset, it's really up to you. Your talking about a 1/4 inch in difference.
