dick0149 Posted May 7, 2008 Share Posted May 7, 2008 i have a 93 sc400.. never had any problems until recently. the ac simply won't blow cold air. the add engine coolant light came on so i added more antifreeze, it started blowing a little cooler, so i figured i had to charge the refridgerant uses r-134 an it's suppossed to read between 25 an 45 to be fully charged but when i hooked up the can an got the initial psi reading from it , it read 90 psi (BAD) !!! any idea's on the prob??? i apreciate the help Quote Link to comment Share on other sites More sharing options...
jzz30 Posted May 7, 2008 Share Posted May 7, 2008 the gauge will read 25-45 psi only when the compressor is running. the fact that there is still gas in the system but your ac doesnt turn on says that there is a slow leak and the pressure dropped below threshold so the compressor wont turn on. take it to an ac shop with a sniffer and they can determine where its leaking from while there is still gas in there. Quote Link to comment Share on other sites More sharing options...
dick0149 Posted May 8, 2008 Author Share Posted May 8, 2008 thanks Quote Link to comment Share on other sites More sharing options...
