mywong23 Posted May 6, 2008 Share Posted May 6, 2008 01 LS430, 107K WP & TB changed at 90K, **************************** on freeway, wife spotted temp guage climbing towards H... I test drive with same symptoms, both fans spinning, radiator full of coolant. turn on heater on HOT; to help lower coolant temp. ************************* bought new thermostat from Lexus Concord, they even matched Toyota's price ($4 less) :) swapped in new gasket & t-stat. temp back to normal (halfway) :D ************************** put old t-stat in hot water, heated to boiling. did NOT open.... Quote Link to comment Share on other sites More sharing options...
jrgraf Posted August 5, 2008 Share Posted August 5, 2008 01 LS430, 107KWP & TB changed at 90K, **************************** on freeway, wife spotted temp guage climbing towards H... I test drive with same symptoms, both fans spinning, radiator full of coolant. turn on heater on HOT; to help lower coolant temp. ************************* bought new thermostat from Lexus Concord, they even matched Toyota's price ($4 less) :) swapped in new gasket & t-stat. temp back to normal (halfway) :D ************************** put old t-stat in hot water, heated to boiling. did NOT open.... is this a replacement you made yourself? i'm doing some routine maintainance on my 1993 ls400 but can't locate the thermostat. any help would be appriciated Quote Link to comment Share on other sites More sharing options...
TexasLexus94 Posted August 6, 2008 Share Posted August 6, 2008 I changed the thermostat on my 94LS with a cheapie simply because at the time, I had several other problems, and wanted to be sure the 'stat wasn't a problem. So I left it in, and have had no problems. I think Paris Hilton could change it out-top hose at the engine block. The only thing I can think of is that it might be installed backwards, or it's the wrong one. Best of luck. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted August 6, 2008 Share Posted August 6, 2008 Good to hear that your wife has an observing eye. On a car that new- many people would never even think to look at the gauge for overheating. I do catch myself occasionally glancing at mine from time to time. Does that car have a chime that sounds when the engine overheats, or when a warning light illuminates? 01 LS430, 107KWP & TB changed at 90K, **************************** on freeway, wife spotted temp guage climbing towards H... I test drive with same symptoms, both fans spinning, radiator full of coolant. turn on heater on HOT; to help lower coolant temp. ************************* bought new thermostat from Lexus Concord, they even matched Toyota's price ($4 less) :) swapped in new gasket & t-stat. temp back to normal (halfway) :D ************************** put old t-stat in hot water, heated to boiling. did NOT open.... Quote Link to comment Share on other sites More sharing options...
