Yes it will fit. It's not a direct bolt in, but the GTE swaps are done all the time. You will have to swap the ECU and tranny, driver shaft and rearend gearing as well, if your gonna do it right. Most just opt to use a stand alone ECU like AEM or Haltech. And you'll need the getrag manual tranny, which is why you'll need to change the driveshaft and rearend gearing.
Alright thankss mannn
