Easy Replacement Key
frolix3
  • 2 months later...
Good for you, thats awesome! So, toy-lex cut a blank key that you sent them, not bought from them? I never knew that anyone would do that.
very timely! my detailer just broke my key...I thought I was out 300 bucks! : )
The "key" to prevent the key breaking when you twist it (no pun intended) is to put a drop of locktite on the little screw that holds the key together (use the non-permanent locktite).
