bradahb Posted December 2, 2003 Posted December 2, 2003 when driving from a complete stop once in a while it feels like its in a higher gear (like 2nd or 3rd gear) also when driving up a steep hill once in a while it shifts into a higher gear (no power) then if you let go of the gas pedal and press gas pedal again then it shifts normal. 3 weeks ago I took it to a lexus dealer for same problem, they checked the car with their computer also road test, they said everything was fine only problem they saw was the transmission pan had a leak. I had them fix that, then from there no problems for about 3 weeks now same problem every once in a while please help thank you
bradahb Posted December 14, 2003 Author Posted December 14, 2003 checked transmission fluid and fluid is not low
