pls help...my right tweeter is not working. I took of the door panel and checked the wirings...evrything looks good. what could be the problem? thanks!
blown tweeter. Need to replace it then. If you have the panel off, try hooking up a different speaker to that connection. If you have sound, then it's the tweeter. If no sound then it's the wires, or the power feed/ amp.
thanks ..just in case were do i locate the power feed amp
It's next to the glovebox on the passenger side. You will have to remove the glovebox and then look to your right.
