Daniel CC Posted February 21, 2008 Posted February 21, 2008 Ok, i have a 2001 is 300, i looks like my window is out of the track so i was wondering how can i take the door panel off, cause when i trie to pull it off it feels like theres like a screw or something by the twirer or something, can somebody help me plz.
smooth1 Posted February 21, 2008 Posted February 21, 2008 Look in the door handle, remove that screw. Slide a putty knife under the switch plate and lift it off. Then disconnect it. Go to the outer edge of the door jam. remove those screws. I can't remember if I had to remove the tweeter housings or not. I don't think I did, but then you have to take the panel in both hands and lift it upwards and off, be careful the door lever.
Daniel CC Posted February 22, 2008 Author Posted February 22, 2008 Look in the door handle, remove that screw. Slide a putty knife under the switch plate and lift it off. Then disconnect it. Go to the outer edge of the door jam. remove those screws. I can't remember if I had to remove the tweeter housings or not. I don't think I did, but then you have to take the panel in both hands and lift it upwards and off, be careful the door lever. I did that already but i dont know why it feels like theres something holding the door habdle and thats why i can pull it up and off, you have any idea what im doing wrong?, is there like a screw holind the door handle to the door???
smooth1 Posted February 22, 2008 Posted February 22, 2008 yes. look in the part where you put your fingers in to pull the door closed.
