qqtravel Posted February 18, 2008 Share Posted February 18, 2008 Newbie to the site. The headlight bulb on the passenger side of my rx330 is out, does anyone know if it is a simple replacement or do I need to bring into the deal to fix? Checked with the dealership but they want over $300 for inspection not including fixing the problem.. Thanks! :) Quote Link to comment Share on other sites More sharing options...
rxpx40 Posted February 22, 2008 Share Posted February 22, 2008 You should be able to reach the passenger side headlight easily on the 2004 model. Do you have the xenon HID's? My wife's '04 has the halogen headlights. Remove the large plastic cover that is above the coolant overflow and windshield washer bottles and you can access the headlight plug from behind the headlight assembly. Rotate the plug 90 degrees to release it and pull the lamp with the plug. I plan on changing my wife's standard halogen lamps out this Saturday to Sylvania Silverstars. I can take pictures if you wish. Chris Quote Link to comment Share on other sites More sharing options...
KBRX330 Posted February 27, 2008 Share Posted February 27, 2008 Please post pics because I know mine will blow out just from reading this thread. The drives side is the tough one as you have to remove the battery. Quote Link to comment Share on other sites More sharing options...
