LC6529 Posted February 16, 2008 Share Posted February 16, 2008 The key fob on my 2002 SC430 is starting to act funny, when I press the buttons on it the red light does not flash until I keep pressing and finally I get a light and the doors/trunk will open. I suspect the battery is going dead since it is the original one. Q: Is this something I can replace or do I need to go to the dealer? Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 16, 2008 Share Posted February 16, 2008 The key fob on my 2002 SC430 is starting to act funny, when I press the buttons on it the red light does not flash untilI keep pressing and finally I get a light and the doors/trunk will open. I suspect the battery is going dead since it is the original one. Q: Is this something I can replace or do I need to go to the dealer? I beleive it is a cr1216 battery, Get yourself a small jewelers phillips head screwdriver and remove the scvrew at the base of the fob, Open it up and simply replace the old battery, Reverse order to put it back together and your done. ;) Buy a couple extra batteries and keep them with the screwdriver in the glovebox. B) 1 Quote Link to comment Share on other sites More sharing options...
LC6529 Posted February 17, 2008 Author Share Posted February 17, 2008 That's what I had hoped someone would say, what I was afraid of was someone would say that it had to be reprogrammed to the Lexus. Anyway, I got a small Philips from my model kit screwdrivers and removed the three screws and replaced the battery (CR1616 - Duracell Replacement = DL1616) and all is working as should. Thanks for allaying my fears! 1 Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 17, 2008 Share Posted February 17, 2008 That's what I had hoped someone would say, what I was afraid of was someone would say that it had to be reprogrammed to the Lexus.Anyway, I got a small Philips from my model kit screwdrivers and removed the three screws and replaced the battery (CR1616 - Duracell Replacement = DL1616) and all is working as should. Thanks for allaying my fears! No problem, That's one of the reasons were here, Happy to hear that all is well in your garage 1 Quote Link to comment Share on other sites More sharing options...
