'02 Gs430 - Adding Amplifier
I was just curious, without spending a ton of money, would it be worth it to add an amplifier and subwoofer to an existing Mark Levinson DVD Nav System? Is so, is there a better way than using a Line output converter? any help would be appreciated. Thanks
Daroll
I used a line out convert on my '97 ES300 and the sound was surprisingly good. I tapped into the speaker line for the sub in the rear, which probably helped to eliminate the right frequencies when blending with the rest of the sound system.
I did too on my 06 gs300. first one (adapter) burned out. get a heavy duty one that handles a lot of watts. also get a class D amp (for sub woofers). they runs cooler.
