hrlychc24 Posted February 12, 2008 Share Posted February 12, 2008 I have a 1995 ES300 My transmission Is working fine but all of a sudden it stopped shifting into over drive..... And the ECT light in the dash is on only when the lights are on when you cut the lights off the light isnt on. Any help will help me at this time. I hate to pay the dealer 100's if their is a simple sensor I could change.... Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted February 12, 2008 Share Posted February 12, 2008 See if you can get any codes read & let us know......I think you can get them read for free at either Pep Boys or Auto Zone......that should narrow things down. Quote Link to comment Share on other sites More sharing options...
hrlychc24 Posted February 12, 2008 Author Share Posted February 12, 2008 :o No codes showed when I did that... I dont know what to do with it Quote Link to comment Share on other sites More sharing options...
wwest Posted February 12, 2008 Share Posted February 12, 2008 :o No codes showed when I did that... I dont know what to do with it Maybe the engine/transaxle ECU has "learned" that your OLD and TIRED engine cannot produce enough torque to sustain OD operation at the low engine RPM level typically involved. Try putting in a FULL tank of PREMIUM, disconnect the battery for 10-15 minutes and then see if OD works. Oh, and a new/CLEAN intake air filter. Quote Link to comment Share on other sites More sharing options...
hrlychc24 Posted February 12, 2008 Author Share Posted February 12, 2008 Thanks I will try that now.... I will let you know if this works :o No codes showed when I did that... I dont know what to do with it Maybe the engine/transaxle ECU has "learned" that your OLD and TIRED engine cannot produce enough torque to sustain OD operation at the low engine RPM level typically involved. Try putting in a FULL tank of PREMIUM, disconnect the battery for 10-15 minutes and then see if OD works. Oh, and a new/CLEAN intake air filter. Quote Link to comment Share on other sites More sharing options...
