Amsoil Power Engine Foam Cleaner
I thought that stuff is more of a manual engine cleaner, to be used with rags and whatnot
Correct me if I'm wrong, but I didn't think it's intended to be introduced into intake hoses with the car running?
How did you run it through? Brake booster? I'd be interested since amsoil's products are fantastic
No, it is made as a throttle body cleaner, intake cleaner etc (internal) along with external surfaces. You follow the directions on the can and no removing brake booster line (which really does not clean well). The car much be running too :cheers:
Unless you buy a can, the website does not explain it very well; but it does state what it can clean (internals and ext).
whats the website? and where did you put this stuff?
