bplaney Posted January 25, 2008 Report Share Posted January 25, 2008 Recently, the control that lets me move the seat closer to or farther away from the steering wheel would stick and the seat would keep moving in that direction until you forced the handle the opposite way. It was also at this same time that the seat would not move at all during the push of one of the saved settings buttons (1 or 2). When the forward/backward seat control resumed working properly (i.e., no longer sticking), the seat adjust function again resumed being part of the overall routine saved in the saved settings buttons. What component is getting ready to fail? thanks! Quote Link to comment Share on other sites More sharing options...
THE ONE Posted January 25, 2008 Report Share Posted January 25, 2008 Recently, the control that lets me move the seat closer to or farther away from the steering wheel would stick and the seat would keep moving in that direction until you forced the handle the opposite way. It was also at this same time that the seat would not move at all during the push of one of the saved settings buttons (1 or 2). When the forward/backward seat control resumed working properly (i.e., no longer sticking), the seat adjust function again resumed being part of the overall routine saved in the saved settings buttons.What component is getting ready to fail? thanks! Same thing that happened to my driver seat...I think that the switch. Quote Link to comment Share on other sites More sharing options...
bplaney Posted January 27, 2008 Author Report Share Posted January 27, 2008 Recently, the control that lets me move the seat closer to or farther away from the steering wheel would stick and the seat would keep moving in that direction until you forced the handle the opposite way. It was also at this same time that the seat would not move at all during the push of one of the saved settings buttons (1 or 2). When the forward/backward seat control resumed working properly (i.e., no longer sticking), the seat adjust function again resumed being part of the overall routine saved in the saved settings buttons.What component is getting ready to fail? thanks! Same thing that happened to my driver seat...I think that the switch. Is this an easy do-it-yourself fix? can parts be found on eBay? Quote Link to comment Share on other sites More sharing options...
bplaney Posted April 6, 2008 Author Report Share Posted April 6, 2008 OK, now the problem is full-blown. I can only adjust the seat with the switch between the driver's seat side and the door. The switch still sticks, meaning I have to slide it backwards (not just let it go) to stop the forward motion of the seat. The steering wheel and driver's mirror work fine. The memory switches NO LONGER WORK. The don't even beep. Question: are the memory switches faulty, or are they behaving this way because the seat adjustment switch is faulty? Can this possibly be a fuse? Quote Link to comment Share on other sites More sharing options...
