Speedo Not Showing Correctly
Assuming you have the correct sized tires, I would connect a scan tool and drive the vehicle. If the speed is indicated correctly on the scantool, the problem is likely the speedometer. If it is incorrectly indicated on the scan tool, I would suspect the vehicle speed sensor. It is located on the rear of the transmission.
