I just had my GS400 washed and noticed that I now have no sound from the radio or CD player. They both seem to function properly as I have not lost any displays and they all function properly other than there is no sound at all. Any and all input is appreciated. Thanks
  • 1 month later...
If you have an amp in the trunk, check to see if it got wet. This occured with my '95 SC400 and the radio/cd died.
  • 4 weeks later...
this just happened to me, drive through touchless carwash, then no radio, well I had radio, but only the low end, bass. If I keep turning it off and on, occasionally i will get the whole thing for a few seconds, then I lose the high end again, with the low end only making anysound. Did you end up replacing the radio, the amp or both? if you had a CD player, did you end replacing that too?
well removed the amp from trunk area cleaned off the corrosion with some cleaner, resealed it. (been in electronics my whole life, so I have some of this stuff lying around) reinstalled, and everything is working. Well except the cd player, sound scratchy, and skips . I suppose being in the trunk for all these years, who would want to work.
  • 4 weeks later...
I have the same problem also, everything is working fine except no audio from the speakers, i tried searching for the amplifier but i have no idea where it is, any comments?
Car:
2003 ES300
Car:
2003 ES300
Car:
2003 ES300
I am frustrated with this same issue and hoped either of you figured it out before I drop a chunk to get it fixed.
Here are my symptoms:
The car is a 2000, and I've only got 25K on it. The audio has worked great since the start. Today, it's raining like cats and dogs (coincidence?) and I get in, crank up the radio and it's going fine. A few minutes down the road, sound simply cuts out... no distorion, just off. The display is still up, and I turn on the CD and it's working but no sound.
I figure that maybe because I had all the ele in the car going: lights, audio, ac on and off because it was particularly humid and I had to defog, wipers, etc that it was a fuse. Later in the day after work, I get in and to my surpriuse the radio is workign again... for about on eminute and then it stops.
It's on again off agin like this. I get it home and am doing some entry level sluething adn it's goes off again.
I know it's not a fuse: blown fuses do not work, they are not off and on.
It's not poor speaker wirng, if so I'd hear distortion and it; would be localized... not all 6 speakers and the sub.
Any help lads?
my email is zenmodo@msn.com
I will all I can, if I figure out the prob, I can maybe help more.
Thanks!
BTW, the amp is in one of 2 places: I know for sur eon my 2000 es 300 it's in the glove box area with the Changer. Othe rlikley spots are under the pass side seat.
I took of fthe glaove box to look around but real;ized I was in close prox to the pass air bag... not knowing chips from crisps, I backed off.
