I am about to change both engine mounts to correct a slight resonance felt in the steering wheel and accelerator pedal at 1,200 rpm under load. I have already changed the transmission mount which took care of most of the above. Are there any precautions I should take while changing out the mounts? Please advise. Thanks all.
buy some universal joint sockets in i think 14mm and you may need a 12mm it makes life much easier. or you can get away with just the univesal joint adaptor but i think its a little harder.
Thanks for the advice on the tools!
