arielscar Posted November 27, 2007 Share Posted November 27, 2007 Bought a replacement unit on ebay (mine has almost totally blacked out screen). Can someone give me (or link me to) instructions on switching them out? Thanks. Quote Link to comment Share on other sites More sharing options...
GaDawg Posted November 28, 2007 Share Posted November 28, 2007 Bought a replacement unit on ebay (mine has almost totally blacked out screen). Can someone give me (or link me to) instructions on switching them out? Thanks. 1. Opne arm rest and pull center cup holder out. 2. Remove 2 screws visible where the holder was. 3. For auto, slide the trim at the base of the dildomatic down, unscrew two screws on stalk, and pull straight up on the shifter. 4. Pull center black trim up and carefully unplug all wiring, then remove ashtray 5. Unscrew screws at the base of the vertical center console trim 6. Carefully, pull up and away on the center console trim 7. You'll now be able to remove the screws on each side of the HVAC that hold it to the bracket. 8. Unplug blacked out HVAC, replace with new one and reverse process. I may have missed a screw here or there (don't think so), if so you'll know and adjust accordingly. Its very easy (if not involved), but once you've done it a few times, its second nature. Have fun. Quote Link to comment Share on other sites More sharing options...
