Trac Problems
VJZ
I took off the sensor directly to the left of the IDLE SPEED CONTROL sensor and now the TRAC light is on. To top that off when you hit the gas, it bogs down the engine such as if you had no traction. If you turn off the traction, everything is fine, but the TRAC light is on.
What is the problem? Will this be costly for just taking off the sensor? Before taking it off everything was perfectly fine.
