orgtech Posted November 10, 2007 Share Posted November 10, 2007 Updated the 2005 Navigation DVD and now the work around for finding a destination while moving doesn't work. Does anyone know of a new work around? Thanks Quote Link to comment Share on other sites More sharing options...
2005 ES330 Salvage Title Posted November 19, 2007 Share Posted November 19, 2007 Updated the 2005 Navigation DVD and now the work around for finding a destination while moving doesn't work. Does anyone know of a new work around? Thanks Most likely you upgraded to the 6.1 firmware, which no longer supports the bypass. There are several options out there to circumvent the problem, which include: - making a hybrid 5.1 / 6.1 DVD, retaining the older configuration files (very difficult) - building a mock speed sensor generator to replace the VSS connection to the NAV unit (difficult, but can be done for $50 by the author, and as far as I know works on the 2007 Tundra. I am building one for my 2007 Camry, as most likely uses the same wiring harnesses. I don't know if this will work with older models, but you sure can try. THIS VOIDS WARRANTIES!!) Once I get this finished on my new camry, I'm going to try on my 2005 ES330 as well, as I don't like to use the bypass method. Here's the website to the VSS emulator: http://www.pinemountainfirearms.com/pmf/tundramods/ and click the "NAV Speed Pulse Generator" link. I'll keep you posted on my progress on this. Quote Link to comment Share on other sites More sharing options...
