rekit Posted November 5, 2007 Share Posted November 5, 2007 93 SC400, 135,000 miles. When I first start it, it makes a fairly loud whirring sound from the trans. It will back out the garage ok, but as the noise slows to a stop-so does the car. Will not go forward or back. The OD light is not sending a code. The fluid is full and does not smell burnt. Does not leak, and recently added 1/2 quart. of Toyota Type 4 to top it off. I have noticed it seemed confused about a gear change 2-3 times in the recent past. Also, I had it sitting for 2 weeks while doing the brake pads (got busy with other things), and the battery had gone flat. After checking for codes, I tried an ECU reset, but it did not help. I saw where you could unplug the ECU on a Supra and test the box for manual gear change, but it appears on SC's the ECU is combined with the engine ecu-so no test driving. Do I need to short the diagnostic plug for the OD light to throw a code? I see some problems are due to bad grounding. Anyone see that cause this problem? What's the best way to trouble shoot this? Thanks, new here from Texas. Maybe time for a JDM or rebuilt with a shift kit and high performance torque converter? I've found a 94 trannie but not sure of the month. I see where they changed in 2/94. Does anyone know what changed, and will it work on my 93? Where is the data plate on these cars? Quote Link to comment Share on other sites More sharing options...
