nswan Posted November 1, 2007 Share Posted November 1, 2007 Hey all. My '99 es300 failed California emissions test with the following results: %CO2 %O2 HC CO% NO(PPM) 15mph 15.2 0 91 1.07 12 25mph 15.3 0 117 1.43 28 I had it looked at by the dealer and they wanted $2000 to replace the catalytic converter and pcv valve. I then brought it to another mechanic and he doesn't think it could be the converter b/c of the sensor ratings before and after the converter. He has guessed that the fuel mixture sensors are bad and need to be replaced. Any ideas?? Quote Link to comment Share on other sites More sharing options...
lenore Posted November 1, 2007 Share Posted November 1, 2007 How many miles on it and did you get the car warmed up to normal before the test? My 99RX just passed with flying colors. I would make sure the oil is new, clean the MAF sensor, and other than that maybe the O2 sensors are bad... Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted November 1, 2007 Share Posted November 1, 2007 I'd go after those same possible culprits... hooking the ecu up to a diagnostics computer is really the only way to know for sure. Quote Link to comment Share on other sites More sharing options...
nswan Posted November 1, 2007 Author Share Posted November 1, 2007 It hass 101,000 miles and has a new MAS. The car was warm before the test and changed the oil about 1000 miles ago. Quote Link to comment Share on other sites More sharing options...
lenore Posted November 1, 2007 Share Posted November 1, 2007 Excessive HC results from ignition misfire or misfire do to excessively lean or rich air /fuel mixtures excessive CO results from rich air/fuel mixtures excessive NOx results from excessive combustion temperatures I would replace the pcv valve (probably less than $8) Have the MAF sensor cleaned Put a fuel cleaner like Techron in the tank and see if it cleans the injectors. clean the IACV (position sensor) All of this is on this site (info) Mine were CO2 15.0 at idle 14.8 at 2500 rpm HC 18 17 CO .01 .00 The bank 1 and 2 oxygen sensors would be last... Quote Link to comment Share on other sites More sharing options...
nswan Posted November 1, 2007 Author Share Posted November 1, 2007 Hey all. My '99 es300 failed California emissions test with the following results: %CO2 %O2 HC CO% NO(PPM) 15mph 15.2 0 91 1.07 12 25mph 15.3 0 117 1.43 28 I had it looked at by the dealer and they wanted $2000 to replace the catalytic converter and pcv valve. I then brought it to another mechanic and he doesn't think it could be the converter b/c of the sensor ratings before and after the converter. He has guessed that the fuel mixture sensors are bad and need to be replaced. Any ideas?? I should also mention that the engine light is NOT on and there are no codes in the computer Quote Link to comment Share on other sites More sharing options...
