90 Ls400 Shows Code 13
dave_m8
My daughter has a 90 LS400 with 170K miles on it, the car suddenly developed a low RPM misfire & the CEL light came on.
I pulled the code & it reads 13, which is " RPM signal no. 2 " (Not much help)
I checked all the plugs & wires, all the plugs seem to be firing & the leads resistance is in the 5-14KOhm
range, including the coil leads. I also checked the compression since I had the plugs out, drivers side cylinders all showed
170psi, the passenger side showed 145-155psi ?
Could something like the timing belt jumping on the passenger side cam wheel cause something like this ?
Anybody had a CEL code 13 diagnosed?
Looks like the problem was caused by the timing belt jumping a tooth on one cam. Replaced the timing belt (& water pump
while I was in there) and the engine runs great again - all cylinders show 170+ psi compression.
Great tutorial on changing the belt/water pump here
http://www.lexls.com/tutorials/engine/timingbelt.html#20
rgds Dave
Here are some pages form the repair manual for "check engine" light problems:
Here's some extra info: MOMENTARY INTERRUPTION
During diagnosis, if Codes 13, 22, 24, 41 or 47 are stored in
ECU memory and no trouble can be found with these circuits, it will be
necessary to perform a momentary interruption test.
1) Clear codes from ECU memory. See CLEARING CODES in this
article. With ignition off, connect a jumper wire between terminals E1
and TE1 of TDCL connector.
2) Start engine. Ensure CHECK engine light goes out. Pull
lightly on wires and apply vibration to connectors and relays
associated with diagnostic codes.
3) During this test if CHECK engine light illuminates, it
indicates which connector or where in the wire harness there is a
fault. Repair as necessary.
4) Clear diagnostic codes. Start engine. If CHECK engine
light does not go out, check thoroughly for faulty connections.
Perform MOMENTARY INTERRUPTION LS400 test again. If CHECK engine light
still will not go out, see LS400 CONTROL UNIT in I - SYSTEM/COMP TESTS
article.
sorry cant upload the info for code 13 but i will find a way to get it on here
rgds Dave
Glad you figured it out, a belt jumping a tooth on a cam cog almost defies logic as the belt is in contact with over 1/2 of the teeth on the cog, but I do believe you. Motors can do weird thinks. I broke a cam in half on a 1.5l Honda motor, cam bearing in the head seized and just twisted it right in half.
  • 4 years later...
