rruotolo Posted October 22, 2007 Share Posted October 22, 2007 I'm dealing with the dreaded servo issue (aka hamster noise) in the HVAC system. I've already removed one of three servo controls, and now I'm in trouble. Any help, and particularly any photos, would be most appreciated. According to my Lexus dealer, there are actually three servo controls: 87106 30371 (air mix) 87106 48020 (air mix) 87106 30390 (recirc. damper) I'm guessing that the two I'm seeing are the first two listed above. I removed the larger of the two that are visible from the passenger area. I opened it up and promptly spilled its contents. So I need to know if I'm putting it back together correctly. Do you know how to set the motor orientation (+/-) and relationship/alignment of feather contacts to the servo wheel, in relationship to the alignment of the white plastic external flange with the track? ANY photos of the correctly assembled (under dash) final product or the innards of the larger servo would be most appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
jimmouse Posted October 24, 2007 Share Posted October 24, 2007 I'm dealing with the dreaded servo issue (aka hamster noise) in the HVAC system.I've already removed one of three servo controls, and now I'm in trouble. Any help, and particularly any photos, would be most appreciated. According to my Lexus dealer, there are actually three servo controls: 87106 30371 (air mix) 87106 48020 (air mix) 87106 30390 (recirc. damper) I'm guessing that the two I'm seeing are the first two listed above. I removed the larger of the two that are visible from the passenger area. I opened it up and promptly spilled its contents. So I need to know if I'm putting it back together correctly. Do you know how to set the motor orientation (+/-) and relationship/alignment of feather contacts to the servo wheel, in relationship to the alignment of the white plastic external flange with the track? ANY photos of the correctly assembled (under dash) final product or the innards of the larger servo would be most appreciated. Thanks. I was in the same boat. What I did is to make sure part number on the little motor visible. Both motors run fine now. Quote Link to comment Share on other sites More sharing options...
rruotolo Posted October 25, 2007 Author Share Posted October 25, 2007 I was in the same boat. What I did is to make sure part number on the little motor visible. Both motors run fine now. Hmmm...very interesting! "Little motor part number visible." Very good tip. Will do! Also, I believe I figured out orientation of internal servo wheel/gear relative to feather contacts by keenly observing wear patterns, and snapping back together with alignment set to mimic previous wear . Should be good to go. Thanks. Quote Link to comment Share on other sites More sharing options...
