Val Posted October 14, 2007 Share Posted October 14, 2007 how to I take out the fog light bulb and a tail light bulb in a 95 sc400 Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted October 15, 2007 Share Posted October 15, 2007 Val, Try Doing a search next time, here are the answer to your questions. Removal of the fog light bulb 1. Take a couple of bolts off on the front fender splashguard, pull back and locate(use a flashlight) the casing. The foglight will be enclosed, with a circular plastic cap. Turn it counter clock-wise to open the casing. 2. This will give you access to the bulb and socket. In the casing is a white plastic, the bulbs connection fits snug into the socket. I had to wiggle and tug, until I jarred it loose. *NOTE* disconnect the wire from the socket before you open the clasp. This keeps the bulb in place and out of your way. 3. To open the clasp, I believe you push down and it will unfasten. 4. When you replace the new halogen bulb don't touch the glass with your fingers, it shorten the life causing it to burn out faster. This site will help with your tail light removal. http://www.clublexus.com/forums/showthread...l+light+removal Quote Link to comment Share on other sites More sharing options...
arielscar Posted October 18, 2007 Share Posted October 18, 2007 As I recall, it was much easier to do with front wheel removed, and car on jack-stand (I think I replaced the passenger side fog light) Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted October 18, 2007 Share Posted October 18, 2007 As I recall, it was much easier to do with front wheel removed, and car on jack-stand (I think I replaced the passenger side fog light) arielscar, You are correct with your statement, but it can be without the step you have mentioned. I advise first timers to jack up the car and remove the tire, my fault for not suggesting this step. Quote Link to comment Share on other sites More sharing options...
