Camshaft Timing Pulley Question
crooner
My camshaft pin broke on my left hand camshaft timing pulley. I just installed a new camshaft and followed the service manual making sure to line up the exhaust and intake camshafts sprockets. After looking in the service manual and my engine I noticed that the right side camshaft timing pulley is pined in the 3v mark. When the pin broke off the lefthand i forgot to look and see which hole the pin was in and it does not say in the service book. Should it go into the 4v spot or 3v spot? In the service book it references the right hand side using the 3v mark. But, makes no reference at all for the left hand side. I would assume it would be 4v since it's a 4 valve motor. Can add pics if need be!
