Hi , can some one help me for the 19" volk wheels, on is350 , Do we need to low the car , please let me know , If we need, like how low . Thank you very much for help.
Do you already have the wheels? If you follow normal convention, yes, you will want to lower the car to achieve the proper look... The tire / Wheel combo will be the same diameter as your current 18" setup. I would suggest using something safe like the Eibach Pro-Kit lowering springs, they lower the car just enough to look good but not so low that everything rubs.
If you need help getting the wheels, tires, or springs, contact me at john@serenitysoundusa.com
Hi , I already have the Blitz Technospeed Z1 19x10 and 19x8 . I thing I need the space for the front wheels , thank you for your help a lot .
Good Luck, and submit pictures after they are mounted. :cheers:
