Is350 (07 Vs 08)
The following changes have been made for the 2008 model year.
1. Destination Package
The destination package for Taiwan has been discontinued.
2. Wheel
The color number for 17-inch wheels has been changed from 11SV14 to 11SV25.
The color number for 18-inch wheels has been changed from 11SV14 to 11CR08.
3. Interior
The scuff plate illumination color has been changed from blue to white.
The front seat backs have been changed to increase the rear seat passenger leg space.
4. Tire Pressure Warning System
In the tire pressure warning system, the following items have been changed.
Changed Item ’08 IS350/250 ’07 IS350/250
Time required for the tire pressure warning
ECU to determine a malfunction in the tire
pressure warning valve and transmitter
20 minutes 51 minutes
The blinking of the tire pressure warning light
between the registration of the ID code of the
tire pressure warning valve and transmitter
and the normal operation of the system
Turns ON after blinking for 1
minute
DTC (Diagnostic Trouble Code)
The following DTC is added.
• C2126/26: Transmitter ID not
received in main mode
5. Multiplex Communication System
DTC B1248 (AVC-LAN communication impossible) has been discontinued.
6. Multi-information Display
French has been added as a multi-information display language on models for Canada. French can be
selected using the customize function.
The following warning messages have been added for all models.
Warning Detail Warning Detail
Buzzer: Sound
07T0NF01C
Key battery is low. (Models
with A/T)
Buzzer: Sound
07T0NF03C
with M/T)
Buzzer: Sound
07T0NF02C
with A/T)
Buzzer: Sound
07T0NF04C
with M/T
You left out a couple of things-
Coinholder added to left of steering wheel
Some minor price changes (you can look these up pretty easily, mostly $200 more for most cars, $200 less for AWD 250s, and a couple minor changes to optioning pkging on the AWD 250)
The wheel color change specifically is to what they're calling liquid graphite, and most people consider it a significant improvement
The seat-back pockets are also different in addition to the leg-room cutouts you mentioned
Some folks have reported (Edmunds among them) that the steering feel/feedback has been improved, but no official statement on that one
The I Agree screen is gone on Nav systems (this might be addable to older models with an updated Nav disc)
