pdufresne Posted October 6, 2007 Share Posted October 6, 2007 So, last spring I started having problems with the RX not starting until after a few tries at turning the ignition. Being that it was the original battery and starter, I replaced both and had no problems until this last week when the same problem happened again. If I put the battery on a charger, it will work for a couple of days before it fail to start. Any thoughts on what could be draining the battery?? Quote Link to comment Share on other sites More sharing options...
lenore Posted October 6, 2007 Share Posted October 6, 2007 Maybe you have corrosion on the battery posts, or the starter posts..... Quote Link to comment Share on other sites More sharing options...
