Sketch_hs Posted October 6, 2007 Share Posted October 6, 2007 Bought a sc400 that was slightly wrecked and fixed it all up it runs but VERY rich so much the cats glow red and there is NO power at all! I disconnected the airflow meter and it runs the SAME! guessing the meter needs replaced? Any other clue? im swapping that out tomorrow! ALSO, the tach just jumps all over the place not showing true RPMS. any easy fix or do i have to replace the cluster? Thanks all for now, thanks guys Quote Link to comment Share on other sites More sharing options...
jzz30 Posted October 6, 2007 Share Posted October 6, 2007 one or both coils are dead. and the tach signal comes from the coil. Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted October 6, 2007 Author Share Posted October 6, 2007 one or both coils are dead. and the tach signal comes from the coil. Would this be causing both problems? I can see the one of the coils on the drivers side... where is the other? Can I do a continuity check across the coil to see if its good? Thanks yall Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted October 12, 2007 Author Share Posted October 12, 2007 IT WAS THE DRIVERS SIDE IGNITER! THANKS SO MUCH! Quote Link to comment Share on other sites More sharing options...
