JIMMYE Posted September 24, 2007 Share Posted September 24, 2007 HI, I'VE GOT A PROBLEM MY PASSENGER SIDE WINDOW IS NOT WORKING AND I CAN PROBABLY FIX IT IF I CAN GET THE DOOR PANEL OFF.DOES ANYONE HAVE STEP BY STEP INSTRUCTIONS TO REMOVE THE PANEL I GOT ALL THE SCREWS OFF 3 ON THE BOTTOM OF PANEL 2 UNDER THE ARMREST AND 2 MORE IN FRONT NEAR THE HINGE. TOOK OFF ALL SCREWS AND IT STILL IS BEING HELD IN PLACE BY THE LATCH AND DOOR LOCK. DOE'S THAT LATCH HAVE ANY OTHER SCREWS. I ALSO GOT THE POWER DOOR AND WINDOW LOCK CONNECTORS OFF.WHAT AM I MISSING IS THERE ANY TRICKS OR SUGGESTIONS ON GETTING THE PANEL OFF SC400 1993 ITS MY PASSENGER SIDE DOOR . MOTOR WORKS BUT WINDOW NOT COMING UP HEAR A RUMBLING SOUND ANY HELP WOULD BE APPRECIATED JIMMY'S LEX IN CHICAGO Quote Link to comment Share on other sites More sharing options...
coolbum_sc400 Posted September 25, 2007 Share Posted September 25, 2007 there is a screw behind the door handle you just need to pop out the plate and there it is. also if you need a new window motor or something i just wrecked my 93 sc400 so i got parts for sale HI,I'VE GOT A PROBLEM MY PASSENGER SIDE WINDOW IS NOT WORKING AND I CAN PROBABLY FIX IT IF I CAN GET THE DOOR PANEL OFF.DOES ANYONE HAVE STEP BY STEP INSTRUCTIONS TO REMOVE THE PANEL I GOT ALL THE SCREWS OFF 3 ON THE BOTTOM OF PANEL 2 UNDER THE ARMREST AND 2 MORE IN FRONT NEAR THE HINGE. TOOK OFF ALL SCREWS AND IT STILL IS BEING HELD IN PLACE BY THE LATCH AND DOOR LOCK. DOE'S THAT LATCH HAVE ANY OTHER SCREWS. I ALSO GOT THE POWER DOOR AND WINDOW LOCK CONNECTORS OFF.WHAT AM I MISSING IS THERE ANY TRICKS OR SUGGESTIONS ON GETTING THE PANEL OFF SC400 1993 ITS MY PASSENGER SIDE DOOR . MOTOR WORKS BUT WINDOW NOT COMING UP HEAR A RUMBLING SOUND ANY HELP WOULD BE APPRECIATED JIMMY'S LEX IN CHICAGO Quote Link to comment Share on other sites More sharing options...
