lafty Posted September 19, 2007 Posted September 19, 2007 I have a 95 LS with the standard 16" wheel. Can anyone please advise what tire pressure should i use according to the factory spec. Thanks in advance.
gordonw Posted September 19, 2007 Posted September 19, 2007 Did you look in your glove box. Back then, I believe they put the tire information in there.
nc211 Posted September 19, 2007 Posted September 19, 2007 yep, or in the armrest, but i believe the glove box has the sticker. Eitherway, it's 32 psi all around, i believe. always check on cold tires though, as heat expands the pressure. The pressure in my 4 runner and wife's Mazda 3 can fluctuate by as much as 5 lb's from hot to cold.
Jerry Bransford Posted September 19, 2007 Posted September 19, 2007 Did you look in your glove box. Back then, I believe they put the tire information in there.There or perhaps on the doorjamb. Just don't go by the tire pressure molded onto the tire's sidewall, that is only the tire's maximum allowable tire pressure, not what is right for every weight of every kind of car that uses that tire. :)
