Memento1134 Posted September 13, 2007 Share Posted September 13, 2007 the lights on the hands on my speedometer/gas gauge, and RPM went out. I heard from someone that this is a common problem in this model. Is this true? If so, what caused it to go out and is there a simple DIY way to fix it? Quote Link to comment Share on other sites More sharing options...
VJZ Posted September 13, 2007 Share Posted September 13, 2007 the lights on the hands on my speedometer/gas gauge, and RPM went out. I heard from someone that this is a common problem in this model. Is this true?If so, what caused it to go out and is there a simple DIY way to fix it? This is very common indeed. Do some searching and you'll find what you need. Quote Link to comment Share on other sites More sharing options...
TexasComputerMan Posted September 16, 2007 Share Posted September 16, 2007 the lights on the hands on my speedometer/gas gauge, and RPM went out. I heard from someone that this is a common problem in this model. Is this true?If so, what caused it to go out and is there a simple DIY way to fix it? This is very common indeed. Do some searching and you'll find what you need. I wonder if you are having a 'plug' problem? Have you taken your cluster out? If so, check the seating of the three plugs in the back. That would be a quick fix. If not. then you may need to take it out and check ther seating/tightness of the guage mounting screws. Read this link to see what I am describing. http://www.clublexus.com/forums/showthread.php?t=214801 Be sure to read the entire link. Toward the bottom I added some additionasl info. B-T-W, my cluster has been working perfectly for months now. Quote Link to comment Share on other sites More sharing options...
