D-double Posted September 1, 2007 Posted September 1, 2007 Does any one know how to replace the tail/brake light on the IS 300 or do I have to pull out the whole light in order to do it.
bartkat Posted September 1, 2007 Posted September 1, 2007 Open your trunk There are two circular clips that you need to take out so that you can access the screws. Once you get those off. Slightly lift up and it will start comming out. DO NOT PULL DOWNWARD Pull it a little up and to the left for the left housing, or right housing. It should all come off. There will be a big circle that you have to turn. and then you will get access to the light bulb.
alohanorm Posted November 19, 2008 Posted November 19, 2008 Bartkat, Is the right process for the bulbs next to the license plate? Alohanorm quote name='bartkat' date='Sep 1 2007, 05:08 PM' post='260163'] Open your trunk There are two circular clips that you need to take out so that you can access the screws. Once you get those off. Slightly lift up and it will start comming out. DO NOT PULL DOWNWARD Pull it a little up and to the left for the left housing, or right housing. It should all come off. There will be a big circle that you have to turn. and then you will get access to the light bulb.
sk1951 Posted December 12, 2009 Posted December 12, 2009 Does any one know how to replace the tail/brake light on the IS 300 or do I have to pull out the whole light in order to do it. Darn...was hoping for a post on this. 96 es300. I need to get to the tail lights too.
