gs400indy Posted August 31, 2007 Share Posted August 31, 2007 i have noticed a strange sound from my gs400 at low speeds. when i turn the steering wheel at rest or at low speeds, there is a creaking/metallic sound from the right front wheel. it like a metal-on-metal sound it only occurs at low speeds. there are sometimes when the sound occurs a lot and then it goes away for a several weeks. it is also most noticeable when the car is cold. it has happened a lot lately, specially under braking at low speeds. could it be brake pad wear or do i have an axle problem any suggestions, thanks Quote Link to comment Share on other sites More sharing options...
mnittler Posted August 31, 2007 Share Posted August 31, 2007 i have noticed a strange sound from my gs400 at low speeds. when i turn the steering wheel at rest or at low speeds, there is a creaking/metallic sound from the right front wheel. it like a metal-on-metal sound it only occurs at low speeds. there are sometimes when the sound occurs a lot and then it goes away for a several weeks. it is also most noticeable when the car is cold. it has happened a lot lately, specially under braking at low speeds. could it be brake pad wear or do i have an axle problem any suggestions, thanks I would check your CV boots or ball joints -- but don't ask me how!! Quote Link to comment Share on other sites More sharing options...
