808-lexus Posted August 31, 2007 Share Posted August 31, 2007 i just bought a connection thingy for my ipod to run through the cigarette lighter, but i discovered that neither lighter is working. how do i find out if it's broken or just disconnected? Quote Link to comment Share on other sites More sharing options...
sonyman Posted August 31, 2007 Share Posted August 31, 2007 Check your fuses first. Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted August 31, 2007 Share Posted August 31, 2007 Check your fuses first. Try it see if you can light a cigarette. Quote Link to comment Share on other sites More sharing options...
808-lexus Posted September 1, 2007 Author Share Posted September 1, 2007 it doesn't even get hot. and how do i get to the fuses? sorry, i'm really a novice at cars.... Quote Link to comment Share on other sites More sharing options...
ryostyle Posted September 1, 2007 Share Posted September 1, 2007 it doesn't even get hot. and how do i get to the fuses? sorry, i'm really a novice at cars.... Look under the parking break release and above the car pedals on the left (towards the door). You'll see a fuse panel cover. Pull the cover and look at the diagram on the cover. There is a fuse designated for that circuit. Pull it, see if its blown, if so replace it with a fuse of the same voltage as dictated on the fuse itself. Quote Link to comment Share on other sites More sharing options...
808-lexus Posted September 2, 2007 Author Share Posted September 2, 2007 ok, i took the fuse out and, sure enough, it was blown! went to the part store and bought the fuse, replaced it, and now it works!!! thank you for your help!!! :D Quote Link to comment Share on other sites More sharing options...
Silvia96 Posted September 2, 2007 Share Posted September 2, 2007 ok, i took the fuse out and, sure enough, it was blown! went to the part store and bought the fuse, replaced it, and now it works!!! thank you for your help!!! :D for future situations similar to this: any time you have an electrical component or system in the car that simply quit working, or never worked, check your fuses first. It can save you hours...trust me... Quote Link to comment Share on other sites More sharing options...
