dssnosher Posted August 28, 2007 Share Posted August 28, 2007 U-Joint needs to be replaced because it gives me knocking sounds to my steering wheel. I called Lexus and they said its a part of drive shaft and it costs $899 - WOW. Are these joints sold separately? Would anyone know where? I cant find anything on google TIA Quote Link to comment Share on other sites More sharing options...
LexusGS400RacerX Posted August 29, 2007 Share Posted August 29, 2007 Honestly, I can't say that I know, or don't know. However, I do know that the drive shaft can give out at any given time under certain pressure. Such as driving too hard, too rough, or too fast. The drive shaft and the U-Joints are not sold separately, it's the entire Drive shaft. I would check with a junk yard first =] Quote Link to comment Share on other sites More sharing options...
SRK Posted August 30, 2007 Share Posted August 30, 2007 Are you speaking of the u-joints used in the steering shaft to the rack, or the transmission to differential driveshaft u-joints? Be a little more specific, and pehaps relate who diagnosed the problem and why, and we can help. Quote Link to comment Share on other sites More sharing options...
dssnosher Posted September 10, 2007 Author Share Posted September 10, 2007 Are you speaking of the u-joints used in the steering shaft to the rack, or the transmission to differential driveshaft u-joints? Be a little more specific, and pehaps relate who diagnosed the problem and why, and we can help. I'm talking a bout the U-joint that is attached to the steering wheel so probably its the one shaft to the rack. Mechanic told me that my steering wheel vibration is caused by bad U-Joint. My steering wheel vibrates and makes knocking noises when i drive on rough surface. Everything in suspension is tight and new. Recently changed tie rods, ball joints and stabilizers and noone knew where did that knocking vibration on steering wheel comes from. Quote Link to comment Share on other sites More sharing options...
garabaldy Posted January 27, 2010 Share Posted January 27, 2010 I'm having the same problem on my 98 GS400, did you find a solution other than buying a new steering shaft? Quote Link to comment Share on other sites More sharing options...
